21" Sangstercraft C.C. Complete redo!
Labman
First, let me thank all the members, that have knowingly, and through their posts, unknowingly helped me to date.
The project, is of course the Grendel, I had an earlier post, that was replied to, asking about materials.
I did a search, before I started this project, trying to get an idea of a realistic budget, I could't find one, so with others out there that might want to get an idea of what it may cost BEFORE you tear into your project, I will include a running total of MY costs, here in N* central Alberta.
Pls. note, as West Marine in Canada, now uses the same pricing as the U.S. catalog, and has No Duty charges + lower shipping charges, I had to order from them. If it would have been economically feasable, I would most certainly have ordered from our GOOD hosts, iboats!:redface:
I have tried to convert my excel file to a photo file, but I have an issue up-loading to photobucket, i will get it worked out!:D
Labman
Labman
Re: 21" Sangstercraft C.C. Complete redo!
Let's try this again;
GRENDEL BUDGET Paid
West Marine
Railng Hardware
90* Rnd Base Pt.# 7219769 $21.99
90* Elbow Pt.# 72119827 $101.94
60* Angle Brackets Pt.# 7219801 $71.96
60* Rectangular Base Pt.# 7220015 $87.96
30* Rectangular Base Pt.# 7219975 $51.98
90* Tee Pt.# 7219827 $16.99
$352.82
Gauges
Teleflex AMEGA
Hour Meters Pt.# 5343892 $99.98
Fuel Gauge Pt.# 5343546 $29.99
Tachs. Pt.# 5343685 $139.98
Volt Meter Pt.# 5343835 $29.99
Tilt/Trim Pt.# PENDING
$299.94
Switch's
Rule Bilge Pt.# 185423 $26.99
Contura Rocker's Pt.# 7808207 $29.99
$56.98
Lights
Allaround Pt.# 315150 $22.99
Attwood Stern Pt.# 593434 $18.99
$41.98
Electrical Misc.
6 Switch Panel Pt.# 1954916 $44.99
Rule Bilge Pump Pt.# 150602 $74.99
Shurflo Wash down Pump Pt.# 4901-4282 $157.99
Rule Bilge Pump Pt.# 316440 $34.99
Pumpgard inline strainer Pt.# 124297 $25.99
Battery Switch Pt.# 3831393 $42.99
Ign. Switch Pt.# 256248 $30.99
Starter Buttons Pt.# 270876 $49.98
$462.91
Todays order pg.#1
Labman
Todays order pg.#2
Bus-Bars
1/4 x 4 pin Pt.# 192450 $29.99
4 pin cover Pt.# 8646325 $5.99
6 circuit Pt.# 215020 $21.98
Power Post+ 150A Pt.# 540658 $25.99
Power Post Singles Pt.# 163191 $19.98
$113.93
SUB-TOTAL $1,318.56
GST $65.93
Running Total $1,384.49
Pg.#3
Wire
Flat Safety #10-2 Pt.# 297418 $55.80
#12 Yellow Pt.# 443178 $20.50
#12 Red Pt.# 214023 $20.50
#14 Purple Pt.# 102337 $35.98
#14 Yellow Pt.# 385567 $17.99
#14 Red Pt.# 214049 $17.00
#16 Blue Pt.# 431868 $10.75
#16 Grey Pt.# 102121 $56.99
# 16 Brown Pt.# 102097 $35.99
$271.50
Wire Conn./Misc.
12 - 10 Ring Terms. Yellow 1/4"Pt.# 132078 $9.98
12 - 10 Ring Terms Yellow 5/16 Pt.# 436139 $9.98
16-14 Ring Connectors Pt.# 448084 $9.29
Butt Conns. 16-14 Pt.# 106070 $9.27
$38.52
Fittings,Valves & Drains
Deck Fill Locking Pt.# 7870041 $79.98
Thru Hull Vent Pt.# 138792 $21.98
Thru Hull Pt.# 209460 $24.98
" " Pt.# 356321 $25.98
Cockpit Drain Pt.# 207571 $43.98
Tank Selector Valve Pt.#9398926 $45.99
$242.89
Sub Total $552.91
GST $27.65
Running Total 2 $1,965.04
Labman
More!
Seats/Pedestals
One shot Adj. ped. Pt.# 310360 $209.99
Todd Ped.18" Pt.# 9413568 $59.99
Swivel Spider Pt.# 597393 $33.99
Swivel Spider Bushing Pt.# 255341 $12.99
Elite Helm Seats Hb. Pt.# 9409772 $419.98
$736.94
Misc. S.S. Fasteners
#10 x 1-1/2 S.S. Oval Hd. Screws 369449 $33.99
#8 x 1 S.S. Screws Pt.# 369423 $17.99
#8 x 2 S.S. Buglehead Screws Pt.# 536672 $59.98
#8 Finishing Washers Pt.# 368755 $13.99
#6 x1 S.S. Screws Pt.# 2300423 $17.99
3/8" x 3 Hngr Bolts 18-8 S.S.Pt.# 2288819 $25.99
3/8" x 3.5" S.S. Carr. Blts. Pt.# 2288462 $51.98
3/8" Lock Wshr. S.S.18-8 Pt.# 496141 $35.99
3/8" Flt. Wshrs. S.S. 316 Pt.# 121329 $11.97
3/8" Nylock Nuts S.S. 316 Pt.# 496075 $26.99
Latches Pt.# 7219934 $79.96
$376.82
$1,113.7
Allied Plastics
1.5oz. Mat x 50"w 1(44kg.) $237.60
6.0oz. Cloth x 60"w (55yds.) $417.45
Lay-up Resin 5gal. Pails 5 $697.45
Chopped Strand 1.5lbs. $18.69
Cabosil 2.5lbs. $37.82
Micro Balloons 1.2lbs. $21.00
Catylst 1ltr. $21.58
Sub Total $1,451.59
GST $72.58
Running Total #4 $1,524.17
That's over $5500.00 and no wood or tools!:(
oops!
lets get it on dude ! :)
been waitin for this one :)
photo buck is great......i use the bulk downloader and automaticaly resize to 640 x 420 or somthing or other.......then copy the img tag and paste it in your thread.......
really looking foward to this proj ;)
cheers
oops
jonesg
A big reason why you have a huge total is because you are adding everything up. no wonder.
I make sure to throw most receipts away.
I hear all the time " so how much have you spent so far".
Its as usefull as recounting how much I paid in car repairs last yr,
its gone and no regrets. I spent a lot more in bars than boats.!
zach103
where are you getting the prices.. just wondering
Labman
Thank's oops!, like I told you that time, if it wasn't for you I wouldn't have had the guts to tackle it. D*&^ you Oops!:D
The "GRENDEL"
Last time she saw water was 1988, someone removed engine and drive in 1997, she was full of s$%t and covered in mould. I knew I had to have her!:eek:
Waiting for the Ferry, it took 22hrs. to get her home!
Slight leak!
Labman
That would be why a person has a BUDGET, to keep track of what it costs!
I don't care what you spent on car repairs last year either, just what it cost to redo this boat.
The prices and part #s come directly out of West Marines catalog.:eek:
zach103
.. look around compare all the prices between the big boat companies jamestown distributors . west marine. boaters world and my favorite IBOATS.
it'll take a while and you'll most likely get bored.. but i have found west marine to be a little pricey. . just my 2 cents
Labman
Yup Zach, your right, however, if you had read my opening post, you would see that I live in North central Ab., the duty alone, without shipping, makes it impossible to order State Side, and I did apoligize for not being able to use iboats.:D
zach103
oh my fault.. sorry bout that..
Labman
Not An issue Zach, I only wished I had the options you mentioned, if I did live down there, your advice would have been be very helpful. Thank's for trying!;)
SS Flasher
How is this rebuild going? I would love to see a updated picture.
