Timing marks on SBC
kenimpzoom
I can't remember, does each tick mark on the timing tab equal one degree or two degrees?
Small block Chevy.
Thanks, Ken
Kenneth Brown
Re: Timing marks on SBC
Been a few years but I think two. Nova outta be along and can set us both straight.
JustJason
I believe its 2 degrees.... unless somebody can concrete that answer.
Limited-Time
Yep 2 degrees sounds right.......................... come to think of it have you ever seen a timing spec with even numbers......:):)
Philthyphil
SBC ,2 degrees for each mark. A stock type motor from mid 70's on with a vac canister.. Disconnect vac hose, and in most cases look for total advance of around 32 degrees at 2500- 3000 rpm. Thats just a general guide line , don't know what type of sbc you have......cheers
