Re: RDSL-22 Shift Plug (Oops not drain plug)
You can do it, but it requires some patience. It's best if you can lay the engine on its side, but it can be done with the engine on the transom.
The key is a scratch awl or similar tool with a very sharp point. A good strong flashlight is also important.
What you have to do is fish the shift yoke around until the hole in it is lined up with the hole for the pin. If the engine is on the transom, the hole in the yoke is probably below the hole in the lower unit, so start by fiddling the yoke up with your scratch awl. The awl's sharp point will bite a little into the yoke. But, you'll have very little space to work in. Eventually, you'll be able to get the awl into the hole in the yoke and move it into position. Once you do that, leave the awl in the hole until you're ready to stab it with the threaded pin, so it doesn't slip down again. You'll probably have to do this more than once.
It'll help if you haven't removed the lower plug and drained all the oil out, but...
Use your flashlight to help you get the hole into position. The problem is that it'll try to drift back down. That's why laying the outboard on its side with the hole up makes the job easier. Your RDSL-22 weighs about 160 lb., so two guys can easily remove it from the transom.
Another aid, as recommended in the factory manual, is to grind a very short bevel on the end of the pin. Just a little bevel is all you need. It just helps to get the pin centered in the hole in the yoke.
Did I mention patience? This job took me over an hour the first time I did it, and was more than a little frustrating, but the alternative was to pull the bottom of the gearcase, then having to get it properly sealed up again. It was worth the hour.
Finally...don't remove that pin again.
