Does your boat has a bait tank infront of the 18 CC console
phiml
Hi all,
I want to add a 20 gal bait tank in front of the center console. How does your pluming run especially the drain or overflow line run? below deck? 20 gal @ 7 lbs = 140 lbs. Is this to heavy for the front bow of the 18 CC?
thanks
kandil
Re: Does your boat has a bait tank infront of the 18 CC console
it runs under the CC and then under the deck all the way to the back where it has the pickup too next to the plug will post some photos tomorrow
kandil
Sorry I was a bit busy hear are the photos did not clean under the CC yet!!! but you can see the connection. in the rear left the intake with a screen and the drain on the right
phiml
Thank you Kandil. I see the In line and the overflow drain. Does the tank drain to the overflow line?
kandil
If you look at the second photo at the bottom right you will see the drain line and it has a 5/8" plug on the inside of the tank and I think it drains at the rear next to the pickup line photo #1 I think.but I don't know if it is connected to the over flow I have to see it in action but most likely it is connected to it and that will act as a vent when you drain it like the bathtub I can not see under the floor and it is freezing out there I can not test it sorry I have not used it yet the boat is new to me have you used yours and how do you like it what motor you have?
