Hi, I have a 1998 Johnson 50HP 2 stroke. Great motor by the way. On the weekend I was off fishing heading up the river when the revs suddenly increased dramatically and I lost all drive. I put it back in neatral and tried forward again and it was ok at first but under load it did it again, so I tried reverse and same thing under high revs or load it seems to be dropping out of gear. I took the cowling off and checked the linkages, but all fine and doing what they should, so I watched them while driving and they stayed where they should yet it still dropped out of gear. I checked the controls to see if all ok in there, but everything looks to be fine and no wear etc. Something is wrong inside which is the next step having idled it back home in gear fine. Can anyone give an idea of the likely cause before I start dismantling the leg please. Is there a clutch in the leg, it seems identical to a slipping clutch in a motor cross bike to me.
Any help or direction is aporeciated.
