lstortini
Thread starter- Joined
- Sep 2, 2008
- 3
I have a 1995 Yamaha 2 stroke and my problem is cold starting. Ever since I bought this engine new in 1995 it gives me problems cold starting. It will caugh and act like it wants to start then it floods. Pull the plugs, let it dry out and then it will start. When I pull the plastic carborator guard from in front of the carbs and spray starter fluid into the carbs it kicks off and keeps running. Once the engine runs for a couple of minutes I can turn it off and it will start back up with out a problem everytime and will continue to start all day once out on the water. It's tha initial cold start that is giving me problems.
I have changed the fuel/water separator and filter to a higher grade micron filter, I changed the plugs and I am mixing the fuel/oil to a 50:1 ratio. I use the best oil (yamalube) and I burn 89 octain fuel. What is the problem? Can anyone give me some sound advice on how to correct this problem.
Thank you,
Lou:
Thank you,
Lou:
