carb floats needed
dbiberstine
Any idea where I can find floats for my carbs? 84 merc 150 V6 srn 6455211
carbs are WH 27. I can not find them new or used. I suspect I have 2 that are heavy any way to seal them?:eek:
achris
More fish than mountain goat
Re: carb floats needed
Part number 1395-9267.
You could try drying them out and them dripping them in fuel proof lacquer.
Chris...........
j_martin
The old foam floats get sunk by alcohol in the fuel. Merc quit using them in the mid 80's somehwhere. The new hard plastic floats are so reliable that neither Mercury or any aftermarket outfit I know of makes them for replacement. (One has a part number listed, but has never made them.)
Best bet is to buy a set of WH anything carbs, like off a 135 from the late 80's on off ebay, to get the floats. Next is to look around for NOS, but plan to pay 15 - 20 bucks apiece if you can find them.
hope it helps
John
mthieme
hope it helps
John
Hmmm. I had to replace a hard plastic one this summer. It seems they seal failed as it is two pieces. Siearra's replacement is foam. I have four carbs on the bench with foam floats - all in good shape.
j_martin
Are you talking about WH carbs? What is Sierra's part number?
John
mthieme
Hmmmm...I could find the gasket set and needle/seat listed. Looks like you've stumbled upon chickens teeth!
If this is your carb, the float is no longer available.
http://www.mercruiserparts.com/Show...ng&inbr=575&bnbr=90&bdesc=Carburetor+Assembly
The part # is 1395-9267 - superceded by 1395-7623.
Check this forum out - there were a couple guys that either had them or a good lead...
http://checkmate-boats.com/forums/showthread.php?t=6506
also, give www.oldmercs.com a call.
j_martin
Like I said. Been there, done that for a few years on this item.
On the WH's, the hard plastic floats are so reliable and so available used that there doesn't seem to be an aftermarket worth going after.
GLM shows a picture and the part number 77280, but the last time I checked they had not made any. A GLM dealer will "order" it for you, and months later find out they don't actually exist. GLM's ETA list on their site lists it as TBA.
Get some bone 135 carbs and rob the floats out of em.
John
This_lil_fishy
I had to get new floats for my 86 50h motor. The old floats were foam, and the new replacements were plastic. I had to order them direct from a Mercury distributor, as my regular repair shop told me they could not get aftermarket parts for them, and could not order merc parts direct from merc as they will only sell to their distributors.
Look for a local distributor and see if they can help you out. The plastic floats are SOOO much better then the foam ones.
Ian
outhere99
I got mine from BoatFix, but I'd recommend buying elsewhere. (it seemed like it was run out of some guys basement... not very secure). Anyway I replaced the original foam floats in my mercury, and it's run like new ever since. The ones I got were the plastic set from sierra (WM15's I think).
desertratt3
I just bought three plastic floats for my 115 from NAPA...
About 13 bucks each......
