Sawhorse for engine mount
polk county
I have an 8.8 seahorse. Whats the best way to mount it for repair? I was thinking about mounting it on a 2x4 sawhorse. It this enough to hold the motor up? I can picture it falling over.
Any ideas
dajohnson53
Re: Sawhorse for engine mount
I've never had problems the dozens of times I've mounted my 9.8 hp on a 2x4 sawhorse. It's plenty strong. That said, I bought a wheeled engine carrier from Cabelas a couple of years ago and like it much, much better. If I had it to do over, I might build one as shown on the above links, modified a little to better accomodate the actual tub I use to run it in. On the other hand, the one I bought is very light weight and easy to store, move and lift when not in use.
MrGED05
I used a cheap plastic sawhorse/workbench/clamp for mine. Clamped down an artificial transom and braces of scrap lumber. Worked well once I reinforced the plastic legs by screwing sections of 2x4 to the legs. It is also now a much better sawhorse.
Picture attached:
Gary
kenmyfam
Got my 7.5hp Mercury mounted to an old tropical fish tank stand right now due to lack of anything else !!!!
Working great !!!!
tmcalavy
Hit the thrift store and pick up a walker...you know, like the old folks use. The ones with wheels are aces...mount a transom board across the front and Bob's your uncle.
eavega
For my 20 HP, I used a folding three-step aluminum stepstool. The outboard mounted right on the back side, and with the stepstool open, I had three small platforms for laying tools, bolts, manual, etc. I set a two-by-four held on with screws at the top of the stepstool, and the motor bolts right to it.
-E
