I went onto the local Honda dealership yesterday morning and told him I need the gaskets/seals to do a 20 hour service on oil and gear oil (also on my 15 Honda), all he sold me was the neoprene washers for the 15hp and "O" rings for the 225. When I drained the oil, I found an aluminum washer like the Honda car engines have. I did not want to make another trip to town, so, I just reused the old one. Yes?No? Do you need to change the aluminum washer every time? My next recommended change will be at 100 hours, so would that be at 120 hours on the hour meter?
I know on Honda cars, they change the aluminum washer every time and I did have one of those in my shop, from my grandaughter's old Honda, but it was way too big. I did run the motor and checked for leaks, all was OK.
I asked the dealer about flushing with the hose connector on the engine and he said he perfers to use the muffs as he thinks you get a better flush? Yes/no?
Also, I had to use a hand impact type device to get the screws loose on the Honda 225, do they really need to be torqqued that tight, if so, how much/many #'s of torque is required? I will be using the boat again tomorrow so it would be nice to know. I have never lost a screw, etc after a tight hand tightening with a large screwdrive w/good flat tip.
Thanks to all for the right advise I will be getting(hopefully).
