flyfshrmn82
- Joined
- Sep 3, 2008
- 6
I have an 04 Yam 15 2-stroke and would like to take the next steps to getting more power out of it. What are the next and least expensive ways to go about doing this?
Or if you get a wing on your tow trailer, then you can get those flashy valve stem caps, and some ground E-Fex on your trailer. You might feel better about yourself. Yhen you can put some decals on your motor that says that its a 115 instead of a 15. All you need is a extra 1! Then if you run 91 octaine fuel instead of 89 you might just get that extra 100 HP! then all you need to do then is install a fire extinguisher on the door of your honda civic. Then you will have to put some red tape on your busted out brake light. Then remove the duct tape holding the clear plastic sheething on your rear window. Then you wont have to have a second person on the boat to keep squezzing the primer ball so the motor wont quit and just replace the fuel pump gaskets for cripes sakes!!!! Then you will be COOL!!!!
