Hi there,
I have a new to me 1981 7.5 Mercury that will not pump water. The guy I bought it from said it needed a new water pump so I started by installing a new impeller (the old one was trashed - pieces everywhere inside the pump). I cleaned things up, made sure the fins turned with the drive shaft and tried bucket testing it. No water came through the pee hole, just a little bit of exhaust. With the help of a mechanic friend (he is an evinrude guy) we have been able to determine through compressed air and water that the blockage is somewhere in the block itself. When we put air through the telltale output it comes out the exhaust ports fine, but barely trickles out the hole at the base of the powerhead where the copper tube from the water pump connects. At this point I would like to go in after the blockage so my question for you all is where would be the best place be to start (i.e., safest and/or easiest access to the block)? Just by looking at the motor, it appears that the easiest entry would be by removing the side plate (exhaust?) just below the thermostat on the port side of the motor, but I'm not sure how much access I would have. My other idea is the rear plate that holds the spark plugs. Any other thoughts or ideas? Where would be the most likely place in the powerhead where the obstruction is? We were both very suprised that we couldn't free the obstruction with compressed air or the water hose as it has worked in the past on other motors. I haven't seen any other situations like mine on these type of forums before. In case this helps, the motor starts up on the first pull and runs very well, just no water out the telltale.
Thanks for any suggestions,
pete
pete
