duffsevinrude
Thread starter- Joined
- Sep 5, 2008
- 19
Hi guys
Yes I am new but yes I have spent the last 3 days searching through posts, that are very similar to the prob Im having. I have done all the tests you guys suggested except for 1. pulling plug leads off when it begins to die, I did try this but **** myself and nearly tipped the boat. So please dont ask me to try it again.
The problem is intermittent, what happens is sometimes she will pull full throttle but then bogs down and slowly but surely shell be revving but the motion of the ocean slows down, i then back her off and she might pick up or she might not.she only sometimes reaches full throttle with the speed she did last trip. And without that little bit of extra power she wont plane ( She is behind a 12 flat punt, tinnie )
She has had new plugs new fuel pump kit carby pulled down twice( and its clean enough to eat off, new fuel lines brand new fuel line from tank to motor including bulb, which stays full when the problem occurs, head pulled off and inspected, compression test 75psi or whatever with hand pull equal in both cylin new water pump. thats all i can think of for now
So big picture is she breaks down under load, but intermittently and doesnt seem to be missing, its just that she slowly bogs down and ends up with full throttle being equivalent to 1/2-3/4 speed. Could it be coils. its the only thing left ?? Thanks for any help
Duff
Duff
