gnarbrah
- Joined
- Sep 20, 2007
- 140
Hi all - I finally got the time to replace the points on my 1975 Johnson 6. If you look back at my previous threads you'll see that I was having some major "sputtering" problems. I pulled the carb and rebuilt it (cleaned thoroughly and new kit) took it out and had the same problems. I finally got up the courage after reading posts here to pull the flywheel and go for it. Got the flywheel off without too much difficulty and figured out how the points and condensers come out. Got the new ones back in okay. Coils look good by the way. Oh - important to note that when completely cold I had great spark in both plugs before I began this project. I bought a feeler gauge and set the gap at .020 and spun it around and quadruple checked them. I then put the flywheel back on and hand spun it while holding the plugs (one at at time) grounded (as before the project) to a head bolt and nothing.
If you haven't read my old posts the motor ran great for about fifteen minutes then would start sputtering (missing?) and get progressively worse. It would have to sit overnight before it would run good again (for 15 mins)
When I got the flywheel off, one of the points had some rust and the other just kind of looked like there was a little bit of scorch marks (normal?)
Anyway, I'm just hoping someone will have a little more insight on something I may have missed? I do have a manual but it just tells me to hook it up to machinery (that I don't have) to test everything. I know I'm close to being back on the water but the summer is coming to a quick close and I need help!!
Thanks!!!
Thanks!!!
