Due to stiff steeering, I had to remove the steering cable in my '90 Johnson 110 motor, however the cable is seized and is not coming out of the "sleeve" on the motor where the cable slips thru.
I had to use a grinder on the large nut that threads to this sleeve which "buggered" up the threads. Now I need to replace that sleeve. I realize that it actually the pivot point for the motor to be able to raise/lower it. what's that sleeve called and where would I go to buy a replacement?
