puddle jumper
Thread starter- Joined
- Jul 5, 2006
- 3,830
Is there a better set of lights. I'm just sick of cleaning the contacts on my bulbs so my lights work. Any suggestions would be of help.
I have the old 11/57 bulbs. I'm always in salt water and it just corrodes them so fast. I also seen one guy with a sealed bulb set up but it leaked.I was thinking about LEDs. Has any one had any problems when thay hook them up?
You know i was thinking the same thing but using my downrigger mounts to hold the lights.PVC pipes in the transom rod holders with the lights mounted on them does the trick for me. Have used the travel board between the back cleats also. A hinge in the middle of the travel board helps alot.
