Overheating And Water In Cilinder
ADBKOPER
Hi Guys I'm From Belgium
And Having A Problem , Just Bought A Doral 245 Cu From 2003 With Only 45 H On It(boat Was Always On Saltwater).i Took It Out For The First Run I Started With 2 Hours At 1000 Rpm No Problem Thene I Pulled Until 2500 Rpm And After A 20 Minutes The Enginetempalarm Sounded (temp Was Over 200 F) So Checked The Props And Drives Nothing Wrong , I Restarted The Engine And The Tempproblem Was Gone, I Got Further At 1000 Rpm And Oke, After 1 H , I Pulled Again To 2800 Rpm And After 20 Min Again Same Problem I Checked Again And Nothing , When I Tried To Restart The Engine Blocked( Water In The Cilinders) I Didn't Pulled Fast Back And Had No Wave; Also I Checked The Impellers And Oke .
Who Can Help Me
ADBKOPER
Re: Overheating And Water In Cilinder VOLVO PENTA
I Forgot It's A Volvo Penta 5.7 Gxi With Dp F5 Blade Engine From 2003
Lodgepole
Water in cylinders probably means a head gasket. Also an old weak or damaged impeller can provide pretty good cooling at low rpm but will ride away from the pump case and not pump good at higher rpm. Any time you buy a used boat, the first thing you should do is replace the inpeller. Even though it looks OK, it may have softened and not do the job. Check out that water in the cylinders. That can cause serious damage. Be sure head is not warped before you put it back together .
Lodgepole
Also, probably would be a good idea to replace the thermostat
ADBKOPER
ALRAEDY THANKS FOR THE FEEDBACK
I STARTED WITH THE IMPELLER WAS OKE ALSO THE IMPELLERHOUSE
THEN I CONTROLLED THE THERMOSTATE AND WORKED WELL IN HOT WATER
I GOT THE WATER OUT AND MOTER IS TURNING GOOD, BUT WHAT HAPPENED AND MAYBE I WILL GET IT BACK
ANY SUGESTIONS:confused:
Spookeay
Almost sure it's a head gasket or warped/cracked head. I see this in Automobiles in my shop all the time. Classic symptom.
Lodgepole
Just because you got the water out of the cylinders doesn't mean it will stay out. If you keep running it, you will ruin pistons, block, bearings and more. Like Spookeay said, as well as what I told you, this is serious. There may be a crack from an improper winterizing job. Better open it up and do some serious searching. May need to take the head to a shop to have it magnifluxed to find a crack and checked to see if it is warped. Could be more than just a head gasket.
