Re: Does the Mikuni fuel pump work on RD19 35hp?
The benefit to the Mikuni pump is you don't have to replace a bypass cover, or pull one on your motor and drill and tap it, just to add the pump. You can plumb the Mikuni into your existing fuel delivery arrangement, but you have to find a spot to mount it. I was able to mount mine right up against the bypass cover using longer bolts. I'm just guessing that the Mikuni may not last as long as an OMC standard issue pump...new product for me and no past experience.
