I am curious about a red or orange lever (color blind ;-[ ) on carb between
2 intake throats ??!! does this lever regulate idle mixture ? or what is its
purpose ??! i can't get motor to idle after running 1-2 hours then trying to dock !! what should idle rpm be ? & can i adjust rpm at linkage as there is an
adjustment screw to set cam at a higher idle but, i don't want it too high so as to screw up shifting gears !! MR TASHASDADDY ! you have same motor
as mine ! do you have idle problems or know whats wrong !!
see previous posts ! new fuel pump,carbs cleaned,seafoamed,gas tank & lines replaced,new plugs, runs great all speeds to 4200 rpm ! won't stay running to use reverse when docking !! thanks a bunch guys !!! 70 yr old coot but, not a hazard yet ;-]] pls reply 9/13/08
