Kiwi Phil
- Joined
- Jun 23, 2003
- 2,182
As you know, I am a grower.
The trial tunnel house (covered in clear plastic) I put up early this yr has grown good out-of-season stock. I have made it insect proof so i can use it in the summer too.
It is only 48m sq. and 180m cu.
It has 2 insect-screened vents up high, plus same for the double door.
Problem i am having it, it is getting just too hot.
1st week of spring, it has gone over 45 degrees C , and it is rising everyday.
We can't pick in it after about 7.30am.
The easy option is to put a single phase extractor fan on it, but I want to think this one through properly.
I need ventilation when the sun is out, so why not go solar??
I get a lot of sunshine, 10hr per day everyday in summer. Only change in winter is reduction in hrs down to maybe 8hrs.
So my thinking is....why not use solar power.
Done a lot of re-search......mass produced solar extractor fans are too small, expensive, pretty much 'toys'.
If i build one, my limited knowledge says use a 12v motor, connected to a 12v battery (deep cycle....700cca??) with a trickle charge solar pannel.
A large fan itself must be easy to buy.
Casing can't be hard to buy or construct.
But what do i use for a motor...does anyone know what-size motor turns what-sized fan, and what-size power source is needed and what-size solar panel?
Now to go a step further, I am constructing another one of these tunnel houses, 30m x 10m x 4.5m to top of roof which will grow 50,000 plants at a time, so i have to come up with some solutions to ventilation soon.
Are there any experts in the house?
I do have to do something.
Cheers
Phillip
Cheers
Phillip
