hey everyone.new to the forum. my 1989 120 johnson vro is sucking my primer bulb flat at higher power settings and shutting off the engine.i have an integral 90 litre tank and previously changed my bulb with a mercury bulb but it seems to be worst. i changed all the fuel lines from the bulb to the tank.removed the reciever in the tank and i do not have a anti syphon valve installed.theres no filter on the reciever in the tank either, just a straight hose on the end. when i blow in the gas tank vent line the air comes out of the gas filler neck so i don't think the vent is clogged. i want to try to put an aux tank in the boat just to try to see what happens if the problem stays or not. also iam suspecting that the fuel pump may be weak and is not overcoming the new check valves in the primer bulb. Can anyone add some info or thoughts to my problem.thanks
