almost got it guys! check this out (pics inside)
weider1717
it's getting there....i still am not going to be able to get it professinal looking but wow it's looking better and better..not sure how to redo the wrinkled boarder..
what u do think? any tips??
weider1717
Re: almost got it guys! check this out (pics inside)
sure it's.....
8" from top to bottom thats measured in the middle.
8" from side to side this is also measured in middle.
as you can tell the decal curves so so the ends smaller at the end of the decal top to bottom is 7 3/4" and also 7 3/4" at the bottom side to side.
but if you measure in the center of the decal side to side and top to bottom is 8.
do u have anyway of helping me?
here is a picture I took of my original decal I pulled off the flame arrestor cover...
weider1717
wow! how did u do that? can you make is side bow out a little? if not still that helps me a lot man.
the original bows out a little in the centers (which is why it's wider in the center from side to side) on each side but it will still be dang clsoe even if you can't make that attachment do that.
i pmed you my email.
thanks again man!
Does this work for you. I can send you the graphic and you can resize it as you need.
weider1717
what are you guys using to do that? the bow is less than that. I'm using photoshop 6.0 elements i don't see how to do that on there.
BUBBA is SPOT on! his is perfect just needs a bit of a bow to it but less than the one you posted. his has the correct border width and black past the red. It's perfect if I can only take his and put a slight bow to it under photoshop 6.0 elements....i'll be cookin! lol
my email below
thomps4p@yahoo.com
weider1717
ur tha man...going to check email now. thanks again!
Every graphic I post on this site is created within PowerPoint. Since PowerPoint is a Presentation Graphics program it cannot save an individual graphic as a separate bitmap, gif or any other graphic format. I then use a very capable capture program called FullShot to capture just that image, save it as a bitmap and upload it to Photobucket.com. That program allows me to grab anything I see on a screen from an object as small as a period to the entire page and save that image in virtually any graphics format. The image you see is not editable as you see it but is editable in PowerPoint. It is made up of eight curves (two on each side) that were then grouped and copied three more times, and rotated as needed to form the four sides. I inserted a square inside the border and filled it black with no border. I grouped the four sides and used the line color (red) and line width (3pt) tools. Within PowerPoint one need only ungroup the image, grab the center point of each side and drag as much curve or as little curve as needed. It took about 2 minutes to create that piece.
weider1717
woah way over my head silvertip lol
weider1717
Bubba, I sent you a PM
