Ken_R
Thread starter- Joined
- Sep 14, 2008
- 10
Hey everyone,
My son and I spent the last year resurrecting an 18' fiberglass boat and have finally gotten around to the engine. As far as I can tell it has been run once for a few minutes since 2004.
So far I've replaced the fuel tank, fuel supply line and fittings. Rebuilt the fuel pump and replaced the fuel lines and vacuum line. There was one problem where the engine would start out WOT but quickly bog down to where I could barely keep the engine running. I could make about 5 kts back to the pier with the engine fully choked. I went in today and pulled all three carbs and sure enough two of the float bowls were full of dark brown chunks that looked like bark. I was able to blow everything clear with carb cleaner and compressed air (keyboard cleaner since I don't have a compressor.)
So the newest problem...I got it back up to top speed then it started bogging down again and stalled. Once I got it running again, it sounded strong but once I tried to go to WOT it started vibrating and rumbling. Sounds like one of the cylinders isn't firing. It almost sounded like the carbs blew clear but now its missing. On previous outings it bogged down before the engine really warmed up so I don't know if the cylinder was missing before or not.
I checked for a spark when I checked engine compression earlier. On two I was able to get a spark through the plug wire insulation but not the third. I pulled all three plugs, one at a time, and all three plugs were sparking. I don't know how to check the strength of the sparks though, I could use some help there.
BTW all three compressions were good, 120+/-2 psi. I'm running 87 octane unleaded mixed 50:1. I've added Sta-bil for the ethanol and Star-Brite to help clean the system.
Another issue I noticed today is that the voltage meter when the engine is running barely gets above 12 volts.
Obviously I have some electrical problems now and would greatly appreciate some help on where to start. Is there a way to check coil assemblies to see if they are failing, maybe a resistance check across the transformer? Would a failing coil cause the drop in charging voltage or do I need to look at a new stator assembly? The middle spark plug wire seems very loose in the transformer, I can twist it around like in a socket rather than a soldered connection. I have no idea if that is normal or not but the other two don't do that. I've also noticed a mustard colored powder on the outside of all three transformers but do not smell anything strange.
Thanks for your time,
Ken and Donovan.
Ken and Donovan.
