weight of 1997 Rinker Festiva 212
JoChek219
I was wondering if anybody would know or where to find the dry weight of a 1997 Rinker Festiva 212 Boat with a Vortec V6 4.3L gm motor and Alpha 1 Gen 2 outdrive. I am wondering the weight because the boat doesn't come with a trailer but found a trailer and not sure if it would be not heavy enough of a duty... If anybody could answer this ? it would be greatly appreciated :)
Thanks Joe
mrainey889
Re: weight of 1997 Rinker Festiva 212
Sorry, I know this does not answer your question, but it might help. Contact either a dealership that sells Rinker boats, or the manufacturer of the trailer you are looking at. One of the two, if not both, should readily have the correct answer.
Regards,
Mike
eaglejim
hey jochek,appox 2775 pounds with empty fuel tank. Check the front of forums page go down to the Rinker boats it has your boat listed hope that helps Jim
JoChek219
ok thanks guys I'll do that
you can look it up at Nada Boats, it shows the dry weight out of the factory.
