rs2k
Thread starter- Joined
- Aug 2, 2008
- 486
My old Rochester carb is worn out and has has a remote choke design and is on an intake that doesn't accept remote chokes. I really need to replace it before I take this boat to the ocean. I'm looking at either another Rochester or maybe a Holley or Edelbrock marine carburetor.
I have a 1981-ish Chevy 305 HO with 601 heads, a stock iron spread bore intake and an unknown cam (could be a truck cam or a marine cam). It is in a 3000 lbs boat with a top speed around 35 MPH with my 14 pitched prop hooked up to a stringer drive. If my tach is correct I cruise around 3000 RPMs at 25 MPH. I am planning on getting a 16 pitched prop in the near future.
I am unsure as to which carburetor I should get to replace my worn out Rochester. What are the differences between the 3 brands? I know I will either need a new intake or an adapter to make the square bore carbs fit, but that is OK. I'd rather put the better carb onto another intake than stick with the easy to do.
