97formula1234
Thread starter- Joined
- Sep 15, 2008
- 10
So i have had this boat (1989 Maxium i/o open bow) for about a month now.
Had it out a few times and it seemed great.
One problem tho, the past owner put in a 15 Gal gas tank under the rear seat because the factory gas tank was contaminated he said. Also the carpet was in pretty bad shape. I decided to pull the carpet and the floor to get to the gas tank. I am still not sure about what i found. There was untreated 3/4 plywood under the carpet. It was pretty rotten. I pulled up the section between the back of the seats and the engine compartment. Under their was some more wood that was totally rotted and falling apart. I pulled the middle section off with the back of my hammer, it just pulled apart all the way to back of the seats then it was a little harder and i could break it. The front half of the boat was also covered in untreated wood, but i have not pulled that up yet.
I was going to just pull the floor up and put down some new plywood and put some resin or whatever on top of it. But after reading here i think i need to check the boat out some more.
So what do i check and how do i check it. I guessing i need to pull everything out? Seats? Stering consoul?
