gene8084
Thread starter- Joined
- Sep 29, 2007
- 187
I have a 1974 Mercruiser 188 I/O.
Experiencing sagging of the outdrive and need to tie the drive up for trailering. I have rebuilt the RAMs but no change.
I'm trying to isolate the problem before taking the more expensive (~$300) route of replacing the pump with a newer model that would allow by-pass of the original reverse lock.
How does the reverse lock work and what part does it play in ensuring the outdrive stays in the up position?
What is the default position of the reverse lock valve? Open/Closed
Does power to the reverse interlock switch open or close the valve?
Is there some way I can test the electric switch dry? (i.e. remove, key to on, shift to reverse/forward or trim up/down?
Thank you.
As always, open to other suggestions and troubleshooting tips.
