FreeBeeTony
- Joined
- May 15, 2002
- 3,995
How much tongue weight is correct? Is it a percentage of the total weight?
what about towing a non boat trailer? I have a 4x6 utility trailer for hauling firewood... is tongue weight important in this case?
5% to 10% is a good guideline. With experience you will find what is right for your particular outfit.
I just bought a 21ft Easy Loader trailer to convert into a pontoon boat trailer. The previous owner used it to carry a 19ft heavy boat until he bought a new trailer. This trailer is heavy duty so I know it will carry my 20ft pontoon boat with ease. My question is, will I have to change the axle location in order to get the correct balance & tongue weight or should I leave it where it is now since it was set up this way at the factory?
My pontoon is fairly light as it doesn't have much furniture on it nor do I plan to have a lot either & the engine is a Johnson 70hp with T/T. I "guesstimate" the weight with the engine, batteries (2) & 12 gallons of gas to be somewhere around 1600-1800 lbs at most. The galvanized trialer I am converting is rated for a 3600 GVR boat so I know it will handle the 'toon OK. I'm trying to figure out how to set up the balance point to start with if I can so I won't have problems with it the first time. It also has 15" tires & wheels which I intend to change to 10" wide profile as I hear they are much better to use towing a pontoon boat. Any suggestions would be greatly appreciated. Thanks
