nobrainsd
Thread starter- Joined
- Jul 19, 2008
- 230
I just got a custom aluminum tank. It has a grounding tab. I have read some other posts on this site, checked what CG regs I could find and I asked the manufacturer. The salesman said that the tab was primarily for use with a fuel level sending unit return, but that grounding the tank wouldn't hurt. The various posts I've checked call for grounding the tank, but vary as to whether I should run the ground wire to the negative battery terminal or to a grounding plate mounted in contact with the water. Seems to me that would be the most reliable ground in that it would not be disconnected by battery isolation or outboard removal. Since the tank is "permanently" mounted (not portable) the CG does require grounding, but doesn't specify the method. I'm intending to run a ground wire to an anode I have installed on my ss trim tab plate. Any comments or suggestions to set me right or at ease about this application?
