trim and tilt
Jim Mcrae
:confused: I have a 1988 OMC 5.7 litre engine and when ever I press the trim and tilt button on the throtle the volt meter drops and the engine stalls. Anybody got an idea?
JustJason
Re: trim and tilt
you probably have a shorted trim motor.....
its eating up all the current and the ignition coil doesn't have enough voltage to fire.
Jim Mcrae
Re: trim and tilt
Can the electric motor be easily separated from the pump and replaced.
wire2
Re: trim and tilt
Is the wiring original? Someone may have taken +12v from the purple ignition wire to feed the trim pump. That will cause the effect you describe.
The solenoids should be supplied directly from the +12v starter stud, through a fuse or breaker.
Jim Mcrae
Re: trim and tilt
Thanks Wire 2, I did have a purple wire in the wrong place and it works great now. Jim
