Re: Marine Radio Antenna length
Most VHF antenna have a 50 ohm impedence and require no tunning or cutting coax. I always take my SWR meter with me when we go to the Pacific Ocean and I have help many solve radio problems back in the camp we all stay in. The only antennas I have seen with high SWR were either shorted Coax where the conector was soldered on, cut coax where it went thru the deck, broken coax where it bends sharp each time they lay down the antenna. I did see one where the antenna was mounted on the deck of the boat along side a metal cab and it had a high SWR over 3 to 1.
The other problem is the antenna it self. The cheap flexable the radiator inside offten break. Some are just tuned Coax.
The bigger stiff antennas hold up much better over time. They also have better Radators, solid brass or copper and receive and transmit much better even thou they are rated as 6 db the same as the little flexable 8 foot antennas.
Most Trailer boats should use a 6 DB gain antenna.
Sail boats that heel over should use a 3 db antenna mounted on the mast head. This is because the 6DB atennas transmit in a narrow horziontal plane and when the boat is heel over the signal is either going into the sky or into the ocean.
The 9 db gain antenna should only be used on larger boats. This is because they have a even more narrow horziontal plane and when the boat pitches and rolls in ruff water the signal could drop out.
Since all the one I have seen were 50 ohm inpedence you can cut the coax to any length and have no affect on the SWR. This is totally different than most CB or Ham Radio's.
My self I never cut one shorter than 6 to 9 feet. When done I always check the SWR Just to make sure everything is good.
I have two CB SWR meters and neither will work at the Higher VHF frequency, My 2 meter ham VHF SWR works good for 2 meters to 440 ham band and VHF Marine.
http://www.shakespeare-marine.com/faq.asp
