Yamaha 50 hp 2 stroke pee hole
stormiespop
Hello, I cannot locate the pee hole on my 2006 Yamaha 2 stroke 50 hp. There are two ports on the back that look like water would come from but nothing comes out. Any help?
Yamajoe
Re: Yamaha 50 hp 2 stroke pee hole
remove the cowling cover and have a look at the back of motor (spark plug side) and on you will see a black tube (5-8mm diam)that comes from the motor, and attaches to a plug on the bottom of the cowlling; locate the exit point; get a tin wire and stick in into the tube to clear what is more than likely a wasp nest.
stormiespop
Thank you very much, I have found it. There was something clogging it. Thanks, you have been a great help!
