dieselmekanix
Thread starter- Joined
- Jul 9, 2008
- 6
Have a rough running 1984 70hp Johnson at around 1500-2500 rpm, The things I have done so far are carb rebuild,fuel filter, new fuel pump, new plugs wires and coils, new cdi,new timer base, new head gasket,carb gasket, new exhaust manifold and gaskets,timing only at idle ok, compression tests around 130psi in all cylinders, the engine idles good and has power on the top end but seems to load up or loose a cylinder when cruising at 7 knots on my 14ft RIB. runs fine for about 5 min. when first starting out. bought the engine used and dont know the history, has any one had this problem? any help would be appreciated , bout ready to throw it in the drink.
