Andreas G
Thread starter- Joined
- Sep 22, 2008
- 16
Re: Not enough RPM at 6.2 mpi / sea ray 270
the last mechanic used mercruser diagnostic soft.
he press the Throttle at wot and it was 80,9%. this is position?
Anyway, I test it at wot by pressing the plastic where the cable throttle ends and nothing happened. The engine went at 3000 easy but, 3400 after 2min and 3600 only when I turn the boat to heave the wind at the back.
As for the IAC the engine doesn?t have any active fault at all, the mechanic said that it doesn?t work correct.
I am totally disappointed.
Tuna fishes and I cant do anything about it??????.!!!!!!!
Every body say that the IAC can?t fix the RPM problem even if I replace it.
If the filter which is under the IAC is dirty can do me the RPM problem?
Can it be an ignition coil problem that the mechanic and the mercruiser diagnostic sys cannot understand it?
