165 Merc will not go to WOT (stays at 2700RPM)
lenny2113
Good day fellows,
Prop has been changed from 21 to 19 pitch
Compression tested (120)
Engine runs fine, but will not go past 2,700RPM.
What is next?
Thanks
jerryjerry05
Re: 165 Merc will not go to WOT (stays at 2700RPM)
Fuel filter,Fuel filter in the pump/fuel pick-up in the tank.The timing/dwell needs adjusting. Linkage? Jerry
Don S
List of possible causes of low WOT.
Engine Won't Reach Operating RPM. Check
  • Fuel condition. Type and Octane possibly old fuel
  • Propeller pitch or diameter, damaged blades
  • Restricted fuel pickup tube or anti siphon valve Fuel System Test
  • Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
  • Marine growth on hull and outdrive
  • Wrong gear ratio in outdrive
  • Restricted carburetor air intake (clogged flame arrestor)
  • Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
  • Poor cylinder compression Compression Test
  • Carburetor defective, or wrong type.
  • Fuel pump pressure and vacuum
  • Boat overloaded, improperly loaded, or improperly trimmed.
  • Engine Overheating
  • Engine timing and ignition system operation
  • Remote control cables and linkage for proper travel to open throttle plates fully.
lenny2113
Super Super !!! Don, I thank you kindly !
Lenny
hoot
ignition coil breaking down...
