Hello all.
Did a quick search in this forum on the problem I have above and it appears that this happens to a variety of engines due to the gas blowing through the carbs into the airbox.... I am going to replace the gasket to the airbox cover and check for any blockage in the airbox drain hose to see if it will help slow down this oil leak into my engine case.
I also read that it could be from the way you store the engine while not in use... I usually tilt it up until I can engage the tilt bracket. Should I not do so while keeping it out of the water? I try to get the boat in the water every weekend, and did not think that having the motor tilted up while out of the water for that timeframe was not a good thing..... should I tilt it down when sitting? how far should i tilt it? just before it engages into trimming portion?
any help or suggestions would greatly be appreciated. thanks in advance...
Mark
Mark
