Johnson Super Seahorse 1963 75hp
Seahorse63
My motor is not firing on cylinders 2 and 4. Does each set of points fire a pair of cylinders?? Please help.
Seahorse63
Points
Points
Does each set of points run all 4 cylinders or just 2 cylinders on my 75hp Johnson?
Re: Johnson Super Seahorse 1963 75hp
double posting is a no, no. TD.
Seahorse, Each set of points fires 2 cylinders. However, they do not operate independently. The cams overlap such that one set of points opens, and the second set opens and the plug fires.
There should be a timing mark on the distributor pulley base. One set of points should open when ths mark matched the mark on the pulley. 90degrees away is the second timing mark on the pulley base. the second set of points should open at this spot.
Joe Reeves
Seahorse..... One set of points fires cylinder # 1 and #3, The other point set fires cylinder #2 and #4.
You have either a broken or missing wire that connects the points, or a faulty set of points.
