hydrofoil
patrat
i was wondering my boat right now is set up preety good i raised the motor up 11/4 on the transom and it gets up and goes at 26mph but i get alot of water kicking up in the back of the boat i was thinking about puting a stingray hydrofoil on. it is a 15hp honda fs with a 14ft deep-v boat well this give me more speed or well it make more drag.remind you this boat goes nice but i want more without spending alot of money.thank you pat:)
Barnacle_Bill
Re: hydrofoil
Hydrofoils will not give you more speed. They will slow you down just a little.
patrat
Re: hydrofoil
thanks bhile so what could i do to gain more speed .
mthieme
Re: hydrofoil
There is no substitute for cubic inches.
Second option - lighten the load.
redeye1962
Re: hydrofoil
I like the way the hydrofoils make the boat plane and steer better.
5150abf
Re: hydrofoil
Raise the motor as high as posssible without cavitating, that is free speed.
The only way to get more speed in a boat is with more power or less weight, you have a 15 horse motor so your speed is limited by that.
Agree, with that small amount of power I think a foil would slow you down.
Dhadley
Re: hydrofoil
It depends on what you mean by the water kicking up in the back of the boat. Coming in while running? Or when you slow down. If you get a spray coming straight up the back of the transom the most likely the motor is too low or there's something dragging in the water.
Properly used a fin can be a tool that allows you to do other things that may increase speed.
patrat
Re: hydrofoil
thanks everyone i dont want to go with a much bigger motor because the boat is only at 195lbs dry and if i put a 25hp on it the motor well be about the same weight as the boat.i well not use a two stroke so i would stay with a four stroke and most likely with a honda and if i went with a 20hp it is the same ccs but more weight so i guess i have too throw the wife out of the boat lol thanks.pat:D
Barnacle_Bill
Re: hydrofoil
Make sure the boat is loaded evenly. Check the motor height. The anti cavitation plate should be as close to even with the bottom of the boat as possible. If that is all correct, try raising it a little as mentioned.
