Re: Can't get sterndrive removed from bell housing
It's unclear to me what you are trying to remove. I can't imagine what would just come apart by removing the bolts from the bell housing..
What exactly are you trying to remove? If it's the drive you don't do ANYTHING with the bell housing. If its the engine you also don't bother with it (usually), but you also need to address a LOT of other things like engine mounts, fuel lines etc.
I suspect you mean to remove your drive, and have removed the bolts from the GIMBAL housing but that's obviously not a bellhousing, which is INSIDE the boat.. I'm confused
M
