Bravo I vs. Alpha I
tinman565
Re: Bravo I vs. Alpha I
Whats the difference ? WOW..ok, guess I'll take the first shot at this one guys. Alpha 1 = Chevette
Bravo 1 = 3/4 ton Pickup
Is that simple enough ?
HT32BSX115
Alpha, rated at 300hp or so, raw water pump inside, dog-clutch shifting, only works in one direction (need a reverse rotation model for twins left hand/right hand props...)
Bravo I, II, III, 400+ hp, raw water pump engine mounted, clone clutch shifting turns in either direction, heavier.
oldsquaw76
So the BRavo II and III are the HD models then?
Don S
In case you were thinking about it, they are NOT interchangable. If you have an Alpha transom shield on your boat, you CAN NOT just put a Bravo drive on that transom shield. They may look similar, but they are not.
