bigbroncoxlt
- Joined
- Aug 1, 2008
- 39
Long story short. Boat is an 88 Sea Sprite. 2.5L alpha 1. The original outdrive was damaged by the previous owners running it without oil. I limped it along for awhile untill the input seal began leaking. No point in repairing a junk drive.
Fastforward to lastweekend. I bought a complete upper and lower from a local boatshop. Everything seemed great. Put boat in water and it didn't want to enguage in reverse without grinding. Quick bump of the throttle and away we went in reverse but it was popping alittle. Forward would grind alittle more than it used to, but no big deal. Ran the boat for a max of 2 hours that afternoon with out any issues other than what I thought was going to be a simple shift cable adjustment. Reverse was only used to launch and to back away from the dock.
So today with the boat in the driveway, shift into forward and adjust cable. All seems well. Shift into rev. and with the cable off the shift mechanism and me pulling the cable as far out as possible the prop will do its normal ratchet when turned counterclockwise, but when you turn it clockwise it feels like it locks but apply more pressure and it will skip.
I can turn the engine over with the prop when its engauged in forward. Does this sound like the shift dog is damaged, or is there something I am missing? Cable moves freely and I had no shifting issues with the original drive.
