loveeverybody
Thread starter- Joined
- Sep 24, 2008
- 24
Initially I thought sand ,debris; were suck in the lower unit. After this brilliant
moment, I put in reverse only to notice it was less power,not as smooth and
water pouring over the transom. It was a change on how it performed in reverse! In forward gear it ran just fine. I pushed it to wot, heard the alarm
sound, and backed off the throtle , the alarm ceased. All day no alarm sound
even at higher speed. So I thought, maybe if something got sucked in; it had worked itself out. pulling the boat out of the water I noticed what look like Dirty oil or exhaust all over the lower unit just below the cowl. Once again a first with this engine; Maybe to much oil in gas mixture? Anyway got home ran it with muffs
alarm sounded on start up ; this has never happend before. So I took off the cowl and followed the harness from the control box to the red plug wiggled it a little bit started it up no alarm. engine idles fine runs great and strong. Checked the gear oil GOOD! Well I hope with disclosing these symptoms will
enable you guys out there to figure this one out. Thanks Again!
