OMC speed question
idesign
Re: OMC speed question
There should be threads on the dipstick tube that looks like a garden hose will screw on.Thats the best way to pump the oil out.
Use SAE 30 weight oil. Rotella oil sold in truck stops and auto parts stores is good.Not 10w-30 just straight 30 weight.
Spark plugs are probably AC MR43T or should be,
You need a Marine distributer cap.
Plug wires can be matched at the auto parts store.
You can use a drill pump and attach a piece of garden hose to it,
One like this,
http://www.sears.com/shc/s/p_10153_...& Pumps&psid=FROOGLE01&sid=IDx20070921x00003a
Warm the engine up first then suck the oil out.
All the parts you need for tune ups...
http://bpi.ebasicpower.com/pc/SMI98104___/OMC9K/Ignition+Wire+Set+Delco+OMC+EST+4+Cylinder
thx for reply.
Distributor cap is brand new .
So is only oil change,new spark plug & wire will be required for tune up.is there any thing else i need to change.let me know.thank you
Also i guess engine is 3 lt so i will need to add 3 lt to engine.pls confirm.
Also they have some engine treatment available for car.can we use this in marine engine.let me know.thx
chiefalen
You should buy a manual. Original best. 4 quarts Ph 30 fram filter.
Fishermark
A tune up would consist of new distributor cap and rotor, new points and condenser, new spark plugs and wires.
No. A 3 liter engine refers to the amount of air the engine displaces - has nothing to do with the amount of oil.
idesign
Come some1 tell me if i should do tune now or spring so i can see if it resolves my speed issue.Or should i just winterize the boat now and resume my work in spring.It is getting cold now.i will not be using boat anymore this year.
let me know what u think guys.
thank you
Gary H NC
If its getting cold enough to freeze i would winterize now.
Buy all your tune up parts over the winter and that will give you time to get the service manual and study it..;)
