Have an old calkins trailer whose wobbler rollers have corroded so bad they do not turn. They are 5 in on a 3/4 shaft...two questions: 1) don't know how to remove the shafts. They are so corroded can't get a wrench on them or knock the pins? out to unbolt the shaft. so am considering 2) replacing the smooth rollers with ribbed rollers (that seem to be more available)...question is...is that a problem?
The shaft lengths are about 22-24" with the 5 in wobbler on each end. Can't seem to find shafts of that size with the trailer venders so am considering just buying 3/4 in steel shafts of that length and putting pressure caps? on the ends (seems also to be the most recent method for securing wobbler rollers). Also need to weld the shaft as shown in the picture
Can anyone help with this thinking? Are there alternatives and would it be ok to replace smooth wobbler rollers with ribbed ones?
Sorry to be so lengthy in such a simple subject...but am a newbie and look to the expertise of the many boaters on this forum.
Austin
Austin
