chiefalen
Thread starter- Joined
- May 18, 2008
- 3,598
There seems to be more and more questions here about starting a boat with a carb.
NOTE: These basic instructions are for a COLD engine only.
Very simple, put throttle in neutral, pump 2-3 times, leave throttle 1/3 of the way down and start the motor.
If it doesn't start in 3-4 seconds, let go of the key.
Repeat step one.
After 2-3 tries, stop cranking the motor, something is amiss.
Time after time people run down the battery or burn out the starter cranking a motor that is out of tune, water in the gas or have electrical problems.
Here is a old post. If it doesn't start.
http://forums.iboats.com/showthread.php?t=279525
Good luck.
Repeat step one.
Good luck.
