winner owner
- Joined
- Aug 3, 2008
- 74
I inherited a 1986 Winnercraft 1850 Sea Quest C.C.with a 120h.p. Evinrude V4
VRO ,motor serial # E120TXCUR
G1442751
At home I changed the gas primer and hose then tried to start the motor .. it cranked very slow.I then purchased a 150 amps battery charger with engine start feature.With charger selector on engine start
the motor cranked very good several times but did not start.I had supper and tried again afterwards. this time no crank ? I found there is no power to the ignition key.There is power to the distributor.There is a big plug on the port side of the motor ,one side of this plug goes directly to the ignition key,I found there is no power going from this plug to the ignition key.
Is this plug defective?I was cleaning inside this plug right after I encountered no crank.. and i caused a big spark?Did I create a second problem?
What year is my motor?
PLEASE! Help...sorry for the long post.
P.S.I also later found that I had put the gas primer and hose on backwards!
G1442751
