96 jazz low RPM
bandt0128
i put my 1996 bayliner jazz in the water this morning and i started up just fine and idled around 1000 RPM which from my understanding is where it should be idleing. When i put some throttle to it it seemed like it didnt want to go over 3000 RPM. Some of the time it would tach up but then it would bogg back down and when i reduced the the amount of throttle it would start running fine again but when i pushed the trottle back down it would either top out aroung 3000 or it would stall. any suggestions on what would cause this.
Jeff Walkowiak
Re: 96 jazz low RPM
you are probably starving for fuel ,, you will really need to re do the carbs, I assume you found why it was leaking fuel, also the gas itself could be old and going bad.
JUSTINTIME
Re: 96 jazz low RPM
use the factory manual
you will need your serial number also
2 different manuals on that 120
it also has cdm ignition
you will need an ohm meter to test those, then a special harness for voltage checks to eliminate electrical on motor
bandt0128
Re: 96 jazz low RPM
is there any rebuild kits out there for the carbs for this motor i do have the manuals.
Jeff Walkowiak
Re: 96 jazz low RPM
it's a force outboard powerhead so probably someone who still has force parts you can check with your napa auto parts dealer they carry outboard and marine parts but most of them don't realize it,, have them search in their small engine book.
part number out of their book is 18-7037
bandt0128
Re: 96 jazz low RPM
ok i appreciate that does the kit have new jets and gaskets in it? theres still the question of why it doesnt have problems tacking up when its on the trailer but when its in the water it wants to die after 3000 RPM.
bandt0128
Re: 96 jazz low RPM
i found that carb kit at napa thank you im going to rebuild them and see if that will work
Jeff Walkowiak
Re: 96 jazz low RPM
on the trailer there is no load on the pump and no back pressure in the exhaust ,, a bad motor will run on the trailer and never even start in the water
JUSTINTIME
Re: 96 jazz low RPM
watch out for those kits
i have seen my fair share that do not work
i only use oem parts when i replace things
i never use aftermarket
follow the manual step by step when u sync it also
bandt0128
Re: 96 jazz low RPM
thanks guys im going to try to do this between wed. and sat. i appreciate your help
