trobinson017
Thread starter- Joined
- Sep 12, 2004
- 183
Hey all,
I had a new boat lift installed last year. Since then the cable for the lower beam at the bow end has stretched (I guess) so that the two lower beams (bow and stern) are at the same level. With my boat's hull that means the bow actually dips lower than the stern, hence, no water drains out of the scuppers when it rains. I had a guy trying to start a new dock/lift business give me an estimate and he want's $200 to adjust it. He said he would raise up the lift then chain the lower bow beam to the top support beams on each side, then lower both bow/stern to create slack at the bow and then adjust the cable so the bow will be higher than the stern.
So far I've balked at having him do this. First, because I don't think it's a $200 job, and second, I'm thinking I could do it myself. The more I look at it the more I believe I could do it. I'm not sure if I need to go buy chains or if some strong rope wrapped around the beams 4-5 times would work. I would have to stand on the beam to adjust the outer cable since there's no maintenance platform or catwalk. Since I weigh 211lbs not sure if rope would hold me and the beam. Of course, the boat would not be on the lift at the time.
Has anyone done this? Any advice from a pro?
As always, TIA!
Troll
p.s. I'll try and post a pic or two later.
As always, TIA!
Troll
