A little fuel at the carb opening normal on a 1988 50hp outboard?
gunner1
I rebuilt my carb today and when I went to run the motor, after a some cranking I noticed a bit of fuel spitting out of the carb. Was I flooding the motor?
jerryjerry05
Re: A little fuel at the carb opening normal on a 1988 50hp outboard?
Some fuel is ok a lot is not.Does it spit when running?Does it run?How did you set the air screw? Jerry
gunner1
It only spit when it was cranking for a bit. The air screw is one turn out from seated.
