Knock Sensor Install - Teflon Tape?
Roman S
Quick question about the installation of a new knock sensor. Would it be good practice to wrap a bit of teflon tape on the threads before screwing the knock sensor in?
1987 Alpha 1 - 2008 efi 5.7 L S/B.
ON the oppostie side of the engine there is s small brass plug to install. It has tape on it. Wondering if the same for Knock sensor?
Thanks Roman
Don S
Re: Knock Sensor Install - Teflon Tape?
It would not be a good practice to use teflon tape on any system in a boat. There are better products. Standard pipe dope with teflon in it is 10000% better than teflon tape.
TT wil also insulate the ground to sensors of any kind.
BLinindoll
No. There should already be some kind of junk in the threads... usually orange. That's it.
Don S
That is ONLY if it is a genuine OEM Mercruiser part. Aftermarket manufactures miss that step, along with a few other obvious differences in some parts. How else can they make them cheaper.
turborich
A knock sensor just screws into the block to detect engine knock, pre ignition. There should be no need for any thread sealant, besides it needs a good ground.
HT32BSX115
I seem to remember the service manual indicating specifically to NOT use teflon (or thread sealant) tape on the knock sensor. There's really no reason anyway. You're not sealing anything anyway.
chiefalen
Nothing on the threads.
Was not even going to post when i saw Ht post, cause he got it right, always does.
No anti-seize ether.
Resist the urge to coat every thread with something.
