michiganspeed
- Joined
- Oct 8, 2008
- 4
I acquired a beautiful 1941 Johnson HD-10 2.5hp from an elderly woman whose husband used the motor regularly use until about 9 years ago when he passed away. My question is does this motor have an impeller/water pump? There is a series of holes in the shaft and a hole at the base of the shaft near the cavitation plate. I ask because I put a little fuel mix in the tank after being stored for almost 10 years and it fired on the 4th pull. The 5th pull fired and the motor came to life and aside from a couple hic-ups at first it idles great & accelerates well also. Once it was started and running smooth I looked to see if water was coming out of the holes in the shaft and there was only a faint trickle of water. I did not want to overheat the motor if it was not getting proper water circulation so I shut it off. If this does need an impeller any idea where to find one and how to go about installing it? The motor is absolutely fabulous so I would love to put this on the little aluminum boat I use for small inland lakes and take off my Minn Kota.
